Franz Achatz - Has built a high quality PCB based on the Parallax Propeller(TM) with a host of features ..
It is ideal for both the experienced and novice users .. see the feature list ..
EasyProp Feature List
Propeller Chip with ext. XTAL 5 MHZ
I2C EEPROM
Audio
SD Memory Slot
USB Programming Interface
Ethernet ENC28J60 Interface
XBee Module (optional)
Power via USB
Power via Barrel Connector (6 ...9 VDC)
VGA
TV Video
PS2 Mouse Interface
PS2 Keyboard Interface
Port Pins P0...P27 available via SIL Pinheader
Reset Switch
User LEDs for P22 and P23
VGA and Video can be disabled via the DIL Switches
Professional 2 layer board with toplayer silkscreen
Board dimensions 80x100mm
CDROM with schematics, easyPROP Demosoftware and Manual included
A more detailed description can be found here ..
http://www.igniteautomation.com/easyPROP.html
The manual can be downloaded here ...
http://www.igniteautomation.com/docs/easyPROP_2.pdf
